HP Envy x360 m6-aq103dx Wireless Module Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide is for the replacement of the Wireless Module. You will need a small plastic opening tool and a standard Phillips Head 1 Screwdriver.
Was du brauchst
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
Lift up the port with the tool.
Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
@jchen202 Just curious, what is the Battery Wattage of this HP Envy? I noticed your guide contains a glimpse of the DC IN CONNECTOR , which seems to be identical to my HP ENVY X360 - 15M-BP112DX. How idid your repairs turn out? If possible, would you be able to provide a picture of the DC IN Connector?
