Zum Hauptinhalt wechseln
HP Pavilion 14-b120dx Audio Port/USB Drive Replacement
Erin Lavalla
Erin Lavalla und 4 weitere Mitwirkende
Zuletzt aktualisiert am January 4, 2024
30 Minuten
Mittel
Studierende im Gange!
Bessere Einleitung
This guide will walk you through replacing the audio port and USB drive card using an iFixit PH0 screwdriver and plastic opening tool.
Was du brauchst
Werkzeuge
  1. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 2, Bild 1 von 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 2, Bild 2 von 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: Schritt 3, Bild 1 von 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: Schritt 3, Bild 2 von 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 4, Bild 2 von 2
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Palm Rest: Schritt 5, Bild 1 von 2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Palm Rest: Schritt 5, Bild 2 von 2
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 6, Bild 1 von 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 6, Bild 2 von 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 6, Bild 3 von 3
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 7, Bild 1 von 1
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Audio Port and USB drive: Schritt 8, Bild 1 von 2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement, Audio Port and USB drive: Schritt 8, Bild 2 von 2
    • Carefully disconnect the cable connecting the ports to the motherboard from the right side.
  9. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 9, Bild 1 von 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 9, Bild 2 von 3 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 9, Bild 3 von 3
    • Remove the two 6.0 mm screws from the ports.
  10. HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 10, Bild 1 von 2 HP Pavilion 14-b120dx Audio Port/USB Drive Replacement: Schritt 10, Bild 2 von 2
    • Push the ports to the left and lift upward to remove them safely.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Erin Lavalla
458 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 4-4, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-4, Catania Fall 2016
UMASSD-CATANIA-F16S4G4
3 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
where can I find the replacement part?
edwin abraham - Antwort
Hello, first I just wanted to say thank you so much for writing these guides! You’re a super hero…. now then, I find myself in quite a pickle. I have an HP 15-b123cl with a screen that’s broken. I need to resolder one of the connectors. I have a picture that will show you which connector I need to fix, but I can’t post a picture in this comment section… all I need is a picture of the display connector on the top left of the motherboard. I even checked ifixit for some way of messaging you directly, but no luck :(… all I can think to do is give you my personal email address and hope that you send me something! Anyways… THANKS ERIN
Ethan
ejstepanianATgmail.com
Ethan Stepanian - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 834
