Zum Hauptinhalt wechseln
HP Pavilion 14-cf0014dx Speaker Replacement
Sam Cole
Sam Cole und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 3, 2022
10 - 25 Minuten
Mittel
Action Shots
Benötigt Bessere Bilder
Fehler in den Markups
Fehlende Schritte
Bessere Einleitung
Is the sound not properly playing from your device? Is the audio distorted or not playing at all? If so, the speakers may be faulty and need to be replaced. Follow the instructions in this guide to remove and replace the speakers in the HP Pavilion 14-cf0014dx laptop.
Was du brauchst
Werkzeuge
  • Phillips #0 Screwdriver
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Mehr anzeigen …
  1. HP Pavilion 14-cf0014dx Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Speaker Replacement: Schritt 2, Bild 1 von 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Speaker Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Speaker Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 HP Pavilion 14-cf0014dx Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Gently lift speakers from the device.
  6. HP Pavilion 14-cf0014dx Speaker Replacement: Schritt 6, Bild 1 von 3 HP Pavilion 14-cf0014dx Speaker Replacement: Schritt 6, Bild 2 von 3 HP Pavilion 14-cf0014dx Speaker Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the speakers from the motherboard.
    • Gently pull and remove the speakers from the device.
Abschluss
Sam Cole
813 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 2-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 119
