Einleitung
This guide highlights the removal/replacement of the HP Pavilion 15-ab165us fan. The fan is a part used in electronics to dissipate heat out of the device. When the fan becomes damaged or the device stays at high temperature levels, it is recommended to replace the fan.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Flip the computer over so that the bottom cover is facing you.
Slide the two locks to the "unlock" position and remove the battery.
Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
Use a plastic opening tool to remove the plastic feet.
Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
Flip the computer back over.
Use a plastic opening tool to release the clips holding the keyboard section in place.
Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
