Zum Hauptinhalt wechseln
HP Pavilion 15-au123cl Network Card Replacement
Mohammad Gardezi
Mohammad Gardezi und eine weitere beteiligte Person
Zuletzt aktualisiert am December 28, 2017
15 - 20 Minuten
Mittel
Using this guide, you should be able to replace the network card on your laptop. If you are having internet connectivity issues, this guide could be your best bet for fixing them. Do note that when replacing the part, make sure the gold connection pins are fully connected when putting the network card in place.
Was du brauchst
Werkzeuge
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Mehr anzeigen …
  1. HP Pavilion 15-au123cl Network Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl Network Card Replacement: Schritt 2, Bild 1 von 2 HP Pavilion 15-au123cl Network Card Replacement: Schritt 2, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
  3. HP Pavilion 15-au123cl Network Card Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-au123cl Network Card Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
  4. HP Pavilion 15-au123cl Network Card Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-au123cl Network Card Replacement: Schritt 4, Bild 2 von 2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
  5. HP Pavilion 15-au123cl Network Card Replacement: Schritt 5, Bild 1 von 3 HP Pavilion 15-au123cl Network Card Replacement: Schritt 5, Bild 2 von 3 HP Pavilion 15-au123cl Network Card Replacement: Schritt 5, Bild 3 von 3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl Network Card Replacement, Network Card: Schritt 6, Bild 1 von 3 HP Pavilion 15-au123cl Network Card Replacement, Network Card: Schritt 6, Bild 2 von 3 HP Pavilion 15-au123cl Network Card Replacement, Network Card: Schritt 6, Bild 3 von 3
    • The network card is located at the top left corner of the motherboard.
    • Unscrew the 4.4mm PH0 Phillips screw at the top of the network card.
  7. HP Pavilion 15-au123cl Network Card Replacement: Schritt 7, Bild 1 von 3 HP Pavilion 15-au123cl Network Card Replacement: Schritt 7, Bild 2 von 3 HP Pavilion 15-au123cl Network Card Replacement: Schritt 7, Bild 3 von 3
    • Using the spudger, remove the two gold pins at the top of the network card.
    • It is recommended to gently apply a vertical force upward with the spudger.
  8. HP Pavilion 15-au123cl Network Card Replacement: Schritt 8, Bild 1 von 3 HP Pavilion 15-au123cl Network Card Replacement: Schritt 8, Bild 2 von 3 HP Pavilion 15-au123cl Network Card Replacement: Schritt 8, Bild 3 von 3
    • Lift up the network card and remove it from the motherboard connector.
Abschluss
USF Tampa, Team S13-G3, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G3, Cagle Fall 2017
USFT-CAGLE-F17S13G3
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 31
Insgesamt: 1,710
