Zum Hauptinhalt wechseln
HP Pavilion 17-g192dx Screen Replacement
Was du brauchst
  1. HP Pavilion 17-g192dx Screen Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion 17-g192dx Screen Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion 17-g192dx Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
    Frag FixBot
  2. HP Pavilion 17-g192dx Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
    Frag FixBot
  3. HP Pavilion 17-g192dx Screen Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 17-g192dx Screen Replacement: Schritt 3, Bild 2 von 2
    • Lift the battery up.
    Frag FixBot
  4. HP Pavilion 17-g192dx Screen Replacement, Screen: Schritt 4, Bild 1 von 2 HP Pavilion 17-g192dx Screen Replacement, Screen: Schritt 4, Bild 2 von 2
    • Using the metal spudger, remove the 2 plastic screw covers at the bottom corners of the screen.
    Frag FixBot
  5. HP Pavilion 17-g192dx Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 7mm screws with a Philips #00 screwdriver.
    Frag FixBot
  6. HP Pavilion 17-g192dx Screen Replacement: Schritt 6, Bild 1 von 3 HP Pavilion 17-g192dx Screen Replacement: Schritt 6, Bild 2 von 3 HP Pavilion 17-g192dx Screen Replacement: Schritt 6, Bild 3 von 3
    • Use a plastic opening tool to remove the plastic cover surrounding the screen by running the tool around the edge.
    • It may be helpful to start with the metal spudger then transition to the plastic opening tool because you will need the metal tip get in initially.
    Frag FixBot
  7. HP Pavilion 17-g192dx Screen Replacement: Schritt 7, Bild 1 von 3 HP Pavilion 17-g192dx Screen Replacement: Schritt 7, Bild 2 von 3 HP Pavilion 17-g192dx Screen Replacement: Schritt 7, Bild 3 von 3
    • Remove the four 4 mm screws holding the back to the display assembly with a Philips #00 screwdriver.
    • Remove the two 3mm screws holding the back cover to the display assembly with a Philips #00 screwdriver.
    • Lay the cover on the workspace carefully as not to damage the wires still connected to it.
    Frag FixBot
  8. HP Pavilion 17-g192dx Screen Replacement: Schritt 8, Bild 1 von 1
    • Unplug the wire connected to the display assembly by gently pulling on it.
    • Tape may be holding it in place.
    Frag FixBot
  9. HP Pavilion 17-g192dx Screen Replacement: Schritt 9, Bild 1 von 2 HP Pavilion 17-g192dx Screen Replacement: Schritt 9, Bild 2 von 2
    • Remove the four 3mm screws connecting the display assembly to the metal framework with a Philips #00 screwdriver.
    • It may be helpful to have someone else support the screen while you remove it.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 31
Insgesamt: 552
