Zum Hauptinhalt wechseln
HP Pavilion Sleekbook 15-b142dx Screen Replacement
Jonathan
Jonathan und 8 weitere Mitwirkende
Zuletzt aktualisiert am October 16, 2015
10 - 15 Minuten
Mittel
This guide demonstrates how to properly replace your HP Pavilion Sleekbook 15 Screen.
Was du brauchst
Werkzeuge
  1. HP Pavilion Sleekbook 15-b142dx Screen Replacement, Screen: Schritt 1, Bild 1 von 3 HP Pavilion Sleekbook 15-b142dx Screen Replacement, Screen: Schritt 1, Bild 2 von 3 HP Pavilion Sleekbook 15-b142dx Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Unplug the device before working on it. Begin by opening the laptop and locating the circular rubber covers at the bottom corners of the screen.
    • Remove the rubber circles by peeling them away from the laptop revealing two black screws. Save the rubber circles for later when you reassemble the screen.
  2. HP Pavilion Sleekbook 15-b142dx Screen Replacement, Screws: Schritt 2, Bild 1 von 3 HP Pavilion Sleekbook 15-b142dx Screen Replacement, Screws: Schritt 2, Bild 2 von 3 HP Pavilion Sleekbook 15-b142dx Screen Replacement, Screws: Schritt 2, Bild 3 von 3
    • Use a screwdriver to remove the two 3.6 mm (smaller) screws from the corners of the devices screen.
  3. HP Pavilion Sleekbook 15-b142dx Screen Replacement: Schritt 3, Bild 1 von 2 HP Pavilion Sleekbook 15-b142dx Screen Replacement: Schritt 3, Bild 2 von 2
    • Once the screws are removed, use the included plastic pry-tool to separate the edge of the screen from the frame of the laptop.
  4. HP Pavilion Sleekbook 15-b142dx Screen Replacement: Schritt 4, Bild 1 von 3 HP Pavilion Sleekbook 15-b142dx Screen Replacement: Schritt 4, Bild 2 von 3 HP Pavilion Sleekbook 15-b142dx Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 5.7 mm (bigger) screws located towards the corners of the device.
  5. HP Pavilion Sleekbook 15-b142dx Screen Replacement: Schritt 5, Bild 1 von 1
    • The screen will only be connected by a single cord at the base of the device. Locate and remove the plastic adhesive attached to the cord. After the plastic is removed, unplug the cord connected to the screen.
Abschluss
To reassemble the device, follow the instructions in the reverse order.
5 weitere Personen haben diese Anleitung absolviert.
Jonathan
758 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 3-3, Hickman Winter 2015 Mitglied von USF Tampa, Team 3-3, Hickman Winter 2015
USFT-HICKMAN-W15S3G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 3,365
