Zum Hauptinhalt wechseln
HP Pavilion dv2700 Hard Drive Replacement
Jared Opperman
Jared Opperman und 3 weitere Mitwirkende
Zuletzt aktualisiert am January 5, 2016
1 - 5 Minuten
Leicht
Be sure to turn off the computer and remove the battery in order to avoid any electrical hazards and further damages to the hard drive. An improper shutdown or the hard drive receiving power while being removed may lead to file corruption.
Was du brauchst
Ersatzteile
Werkzeuge
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Mehr anzeigen …
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: Schritt 4, Bild 1 von 2 HP Pavilion dv2700 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Texas Tech, Team 22-6, Rauch Fall 2015 Mitglied von Texas Tech, Team 22-6, Rauch Fall 2015
TTU-RAUCH-F15S22G6
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 3,224
