Zum Hauptinhalt wechseln
HP Pavilion dv6000 Speaker Bar Replacement
Was du brauchst
    1. HP Pavilion dv6000 Speaker Bar Replacement, Speaker Bar: Schritt 1, Bild 1 von 1
      • Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
      • there are three philips screws located on the surface where the writing is. remove those three screws.
      Frag FixBot
      Kommentar hinzufügen
    2. HP Pavilion dv6000 Speaker Bar Replacement: Schritt 2, Bild 1 von 1
      • turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
      • Be sure not to pull hard or you may damage the ribbon cables.
      • From the side closest to the screen turn the cover towards yourself.
      Frag FixBot
    3. HP Pavilion dv6000 Speaker Bar Replacement: Schritt 3, Bild 1 von 1
      • there is one connector from the speaker bar to a control board. Gently remove the cable.
      • There are two more screws attaching the speaker bar to the cover, remove these and take the speaker bar out.
      Frag FixBot
    4. HP Pavilion dv6000 Speaker Bar Replacement: Schritt 4, Bild 1 von 1
      • you are now ready to replace or repair the speaker bar. I recomend purchasing a new one, they range anywhere from 5-15 dollars online.
      Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
how to fix speaker from board
kingsley Osunkwo - Antwort Teilen
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
fernando mancini - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 38
Insgesamt: 4,024
