Zum Hauptinhalt wechseln
HP Pavilion dv6t-1200 Disk Tray Motor Replacement
Was du brauchst
  1. HP Pavilion dv6t-1200 Disk Tray Motor Replacement, Disk Tray Motor: Schritt 1, Bild 1 von 2 HP Pavilion dv6t-1200 Disk Tray Motor Replacement, Disk Tray Motor: Schritt 1, Bild 2 von 2
    • Locate the small hole on the right side of the disk tray next to the release button.
  2. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 2, Bild 1 von 2 HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 2, Bild 2 von 2
    • Extend the paper clip into a straight line and insert it into the disk tray hole located next to the release button.
    • Do not poke the optical light button to the middle left of the release button. The disk tray hole is to the bottom right of the tray release button.
    • When the disk tray is removed, clean your workspace and the tray with canned air.
  3. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 3, Bild 1 von 1
    • Be cautious of the open disk tray.
    • Flip the laptop upside-down.
    • Remove the four screws on the bottom of the disk tray using a Phillips #0 screwdriver.
  4. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 4, Bild 1 von 2 HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 4, Bild 2 von 2
    • Remove the top metal plate of the disk tray and locate the motor.
  5. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 5, Bild 2 von 2
    • Remove and replace the motor piece.
  6. HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 6, Bild 1 von 2 HP Pavilion dv6t-1200 Disk Tray Motor Replacement: Schritt 6, Bild 2 von 2
    • After replacing the motor and screwing the tray back together, apply WD40 to lubricate the tray.
    • The disk tray should now be working smoothly.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
CSU Los Angeles, Team 11-21, Grodsky Fall 2021 Mitglied von CSU Los Angeles, Team 11-21, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G21
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 562
