Zum Hauptinhalt wechseln
HP Pavilion dv9000 Wireless Card Replacement
Erik Hoffnagle
Erik Hoffnagle und 4 weitere Mitwirkende
Zuletzt aktualisiert am March 18, 2014
10 Minuten
Mittel
Many times, connecting to a wireless network can be difficult. Finding the problem that isn't allowing you to connect may be even more challenging. With help from this guide, you will be able to easily replace your laptop's wireless card.
Was du brauchst
Werkzeuge
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: Schritt 2, Bild 1 von 2 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: Schritt 2, Bild 2 von 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: Schritt 3, Bild 1 von 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: Schritt 3, Bild 2 von 3 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: Schritt 3, Bild 3 von 3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv9000 Wireless Card Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv9000 Wireless Card Replacement: Schritt 4, Bild 3 von 3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv9000 Wireless Card Replacement: Schritt 5, Bild 2 von 2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 10-32, Maness Winter 2014 Mitglied von Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 4,018
