Zum Hauptinhalt wechseln
HP Pavilion x360 14m-cd0005dx Motherboard Replacement
Jacob Richardson Earl
Jacob Richardson Earl und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
25 - 50 Minuten
Mittel
Use this guide to aid in the removal and replacement of the motherboard to any HP Pavilion x360 14m-cd0005dx laptop. Replace the motherboard if the laptop experiences frequent Blue Screen of Death errors for no other discernible cause. For more information as to whether the motherboard should be replaced, look at this troubleshooting guide.
The motherboard is an essential part of any laptop. When replacing the motherboard, a large amount of device software will need to be re-downloaded or reinstalled. If the motherboard needs to be replaced but isn’t, the system may shut down without warning and fail to start again. The motherboard is especially vulnerable to damage from static electricity, so be sure to wear an anti-static wrist strap (like the one here) to reduce the risk of harm to the device's components.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 4, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 5, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 5, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: Schritt 6, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: Schritt 6, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: Schritt 6, Bild 3 von 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 7, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Heat Sink and Fan: Schritt 8, Bild 1 von 1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 9, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 10, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 10, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 11, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
  12. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: Schritt 12, Bild 2 von 2
    • Remove all screws securing the motherboard to the device:
    • Ten Phillips #0 4.5mm screws
  13. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 13, Bild 1 von 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 13, Bild 2 von 3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Use the Reverse Tweezers to disconnect the speaker cables from the motherboard.
  14. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 14, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Slide out the ribbon wire from the motherboard
  15. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 15, Bild 1 von 2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Gently lift the motherboard out of the device
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 809
