Zum Hauptinhalt wechseln
HP Pavilion15z-eh000 SSD Replacement
Bryan Segovia
Bryan Segovia und eine weitere beteiligte Person
Zuletzt aktualisiert am December 27, 2022
10 - 15 Minuten
Leicht
This is a guide on replacing the Solid State Drive (SSD) of an HP Pavillion 15z-eh000 laptop. Whether replacing a faulty drive or upgrading for more storage, this guide aims to simplify the process. Before starting, ensure the laptop is: entirely powered off, does not have the power cord connected, and has no external devices connected. Use a workstation that is clean and static-free. While working with electronics, It is recommended to wear an anti-static wrist strap to prevent electrostatic discharge. Make sure to avoid contact with pins, leads, or circuitry.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: Schritt 1, Bild 1 von 3 HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: Schritt 1, Bild 2 von 3 HP Pavilion15z-eh000 SSD Replacement, Solid State Drive: Schritt 1, Bild 3 von 3
    • Remove the two M2.0 × 5.0 Phillips screws along the bottom of the cover.
    • Remove the four Phillips M2.5 × 6.5 screws under the rubber foot pads.
    • The rubber pads have adhesive that allows them to be restuck after being lifted. You do not need to completely remove them, only partially.
  2. HP Pavilion15z-eh000 SSD Replacement: Schritt 2, Bild 1 von 3 HP Pavilion15z-eh000 SSD Replacement: Schritt 2, Bild 2 von 3 HP Pavilion15z-eh000 SSD Replacement: Schritt 2, Bild 3 von 3
    • Use an opening tool to pry open the bottom case, starting from the hinge.
    • Follow along the edge and use the opening tool to lever it open.
    • Recommended to start from the hinge as it will be easier, but it is possible to start anywhere.
  3. HP Pavilion15z-eh000 SSD Replacement: Schritt 3, Bild 1 von 3 HP Pavilion15z-eh000 SSD Replacement: Schritt 3, Bild 2 von 3 HP Pavilion15z-eh000 SSD Replacement: Schritt 3, Bild 3 von 3
    • Remove the six Phillips M2.0 × 4.0 screws holding the battery in place.
    • Lift the battery slightly and pull it to disconnect it from the connector on the motherboard.
  4. HP Pavilion15z-eh000 SSD Replacement: Schritt 4, Bild 1 von 3 HP Pavilion15z-eh000 SSD Replacement: Schritt 4, Bild 2 von 3 HP Pavilion15z-eh000 SSD Replacement: Schritt 4, Bild 3 von 3
    • Finally, remove the Phillips M2.0 × 2.5 screw that secures the SSD to the motherboard.
    • Grasp the SSD by the edges and gently pull it out from its slot.
    • After removing the screw, the SSD will partially lift itself. Make note of the angle. When installing your new SSD be sure to insert it at the same angle.
Abschluss
Bryan Segovia
109 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 3-42, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 3-42, Briggs Fall 2022
CSULA-BRIGGS-F22S3G42
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 662
