Zum Hauptinhalt wechseln
HP Slate 7 4601 Battery Replacement
Zachary
Zachary und 3 weitere Mitwirkende
Zuletzt aktualisiert am October 2, 2018
10 - 15 Minuten
Leicht
Empfohlene Anleitung von Studierenden
After many times of attempting to recharge the battery with no success, it may be time for your Slate's battery to be replaced. This repair guide is the primary step for all future repairs on your HP Slate, and is a basic process to master. In this guide, you will be removing the following:
  1. Back Cover
  2. Battery
Prepare your required tools, a new battery for your tablet, and set aside about 10 to 15 minutes to delve into the inner workings of your HP Slate.
Was du brauchst
Ersatzteile
Werkzeuge
  • T4 Torx Screwdriver
    T4 Torx Screwdriver
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
  • T3 Torx Screwdriver
    T3 Torx Screwdriver
Mehr anzeigen …
  1. HP Slate 7 4601 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Slate 7 4601 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
  2. HP Slate 7 4601 Battery Replacement: Schritt 2, Bild 1 von 2 HP Slate 7 4601 Battery Replacement: Schritt 2, Bild 2 von 2
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
  3. HP Slate 7 4601 Battery Replacement: Schritt 3, Bild 1 von 2 HP Slate 7 4601 Battery Replacement: Schritt 3, Bild 2 von 2
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
  4. HP Slate 7 4601 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the rear cover.
  5. HP Slate 7 4601 Battery Replacement: Schritt 5, Bild 1 von 1
    • Locate and remove the yellow tape covering the red and white speaker wires.
  6. HP Slate 7 4601 Battery Replacement: Schritt 6, Bild 1 von 2 HP Slate 7 4601 Battery Replacement: Schritt 6, Bild 2 von 2
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
  7. HP Slate 7 4601 Battery Replacement: Schritt 7, Bild 1 von 1
    • Gently pull back the foil covering the gold charging port ribbon.
  8. HP Slate 7 4601 Battery Replacement: Schritt 8, Bild 1 von 2 HP Slate 7 4601 Battery Replacement: Schritt 8, Bild 2 von 2
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Battery Replacement: Schritt 9, Bild 1 von 1
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Battery Replacement: Schritt 10, Bild 1 von 2 HP Slate 7 4601 Battery Replacement: Schritt 10, Bild 2 von 2
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Battery Replacement: Schritt 11, Bild 1 von 1
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Battery Replacement: Schritt 12, Bild 1 von 1
    • Lift battery out of its place and set aside.
Abschluss
18 weitere Personen haben diese Anleitung absolviert.
Zachary
1.453 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 13-30, Maness Spring 2014 Mitglied von Cal Poly, Team 13-30, Maness Spring 2014
CPSU-MANESS-S14S13G30
3 Mitglieder
8 Anleitungen geschrieben
3 Kommentare
Buenas tardes, como están? Consulta, la batería se puede reemplazar por otra genérica, existe algún repuesto?
Javier Sanchez - Antwort
Thanx for this amazing demo steps. Sir i need battery of this tab, coz i cant find this battery anywhere then someone told me to go online purchase it wil you so i decided to go online n finally i found ur page so plz arrange me the battery of this tab. My HP Slate 7 battery is not charging . I m from pakistan n my email is aasifbrothers79@gmail.com. Sir i m looking forward for ur kind reply .Thanx
Regards, Asif Sultan
Asif Sultan - Antwort
where do i buy the battery in india… there is a site Maxbhi, I ordered the battery, they never send the battery neither returned the money…
Kapil Baidya - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 29
Insgesamt: 29,867
