Zum Hauptinhalt wechseln
HP Stream 11-d008TU Power Button Replacement
Joel Taylor
Joel Taylor und eine weitere beteiligte Person
Zuletzt aktualisiert am June 24, 2020
30 Minuten
Mittel
Action Shots
Benötigt Bessere Bilder
Benötigt Mehr Bilder
Anleitung eines Community-Mitglieds
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: Schritt 1, Bild 1 von 3 HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: Schritt 1, Bild 2 von 3 HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: Schritt 1, Bild 3 von 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Power Button Replacement, Screw removal: Schritt 2, Bild 1 von 2 HP Stream 11-d008TU Power Button Replacement, Screw removal: Schritt 2, Bild 2 von 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: Schritt 3, Bild 1 von 3 HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: Schritt 3, Bild 2 von 3 HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: Schritt 3, Bild 3 von 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Power Button Replacement, Keyboard removal: Schritt 4, Bild 1 von 3 HP Stream 11-d008TU Power Button Replacement, Keyboard removal: Schritt 4, Bild 2 von 3 HP Stream 11-d008TU Power Button Replacement, Keyboard removal: Schritt 4, Bild 3 von 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Power Button Replacement, Connector removal: Schritt 5, Bild 1 von 2 HP Stream 11-d008TU Power Button Replacement, Connector removal: Schritt 5, Bild 2 von 2
    • Remove the power button connector from the power button by flipping the white tab up and pulling the ribbon cable out
  6. HP Stream 11-d008TU Power Button Replacement, Unscrew Button: Schritt 6, Bild 1 von 3 HP Stream 11-d008TU Power Button Replacement, Unscrew Button: Schritt 6, Bild 2 von 3 HP Stream 11-d008TU Power Button Replacement, Unscrew Button: Schritt 6, Bild 3 von 3
    • Unscrew the two Philips PH0 2.5mm screws
  7. HP Stream 11-d008TU Power Button Replacement: Schritt 7, Bild 1 von 3 HP Stream 11-d008TU Power Button Replacement: Schritt 7, Bild 2 von 3 HP Stream 11-d008TU Power Button Replacement: Schritt 7, Bild 3 von 3
    • Lift the power button out of the slot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Joel Taylor
1.298 Reputation
8 Anleitungen geschrieben
Australia Mitglied von Australia
Community
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 288
