HP Z2 Mini G3 Access Panel Replacement
Einleitung
Zu Schritt 1 der AnleitungThis is the top cover to access the interior components of the HP Z2 Mini G3 (Product No. 1LE81UP#ABA). This guide can direct you to remove the panel.
Be sure to turn off the device and disconnect the A/C power cord before removing the panel.
Components inside the device are also subject to static damage, so try and work on a hard surface to reduce this risk.
Slide and hold the latch in the direction of the engraved arrow (to the right).
While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
