HUAWEI HONOR 5X Fingerprint Scanner Replacement
Einleitung
Zu Schritt 1 der AnleitungIf the device does not recognize fingers correctly, replacing the fingerprint scanner may solve this issue.
Was du brauchst
To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
Use tweezers to disconnect the white coax cable.
Use tweezers to disconnect the power and volume cable.
This is what the mother board should look like when the fingerprint scanner is pulled out.
To fix the fingerprint scanner simply add in a new one and attach the metal component to its coordinating place.
