Zum Hauptinhalt wechseln
HUAWEI HONOR 5X Motherboard Replacement
Gloriane Delgadillo
Gloriane Delgadillo und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
Keine Schätzung
Mittel
The motherboard may have to be replaced if the cellphone is not responding at all. This guide will instruct the steps on this process.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. HUAWEI HONOR 5X Motherboard Replacement, HUAWEI HONOR 5X Disassembly: Schritt 1, Bild 1 von 1
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Motherboard Replacement: Schritt 3, Bild 1 von 2 HUAWEI HONOR 5X Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Motherboard Replacement: Schritt 4, Bild 1 von 1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Motherboard Replacement: Schritt 5, Bild 1 von 2 HUAWEI HONOR 5X Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 HUAWEI HONOR 5X Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  7. HUAWEI HONOR 5X Motherboard Replacement: Schritt 7, Bild 1 von 2 HUAWEI HONOR 5X Motherboard Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  8. HUAWEI HONOR 5X Motherboard Replacement: Schritt 8, Bild 1 von 3 HUAWEI HONOR 5X Motherboard Replacement: Schritt 8, Bild 2 von 3 HUAWEI HONOR 5X Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Remove the motherboard.
Abschluss
Gloriane Delgadillo
97 Reputation
1 Anleitung geschrieben
USF Tampa, Team S7-G6, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G6, Passmore Spring 2018
USFT-PASSMORE-S18S7G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 16
Insgesamt: 1,341
