HUAWEI HONOR 5X Motherboard Replacement
Einleitung
Zu Schritt 1 der AnleitungThe motherboard may have to be replaced if the cellphone is not responding at all. This guide will instruct the steps on this process.
Was du brauchst
To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
Use tweezers to disconnect the white coax cable.
Use tweezers to disconnect the power and volume cable.
