Was du brauchst
Remove the black air concentrating nozzle (shown in the red circle) by gently twisting and pulling the nozzle.
Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
Detach the hair dryer grating from the body by gently twisting the grating from side to side.
Locate the screws on the handle and remove with a Phillips screwdriver
Your hairdryer should now be disassembled and you should easily be able to see the fan, motor, heating element cover, and internal wiring.
After disassembly and isolating the button switchboard, locate the small component that is directly connected to the power cord. Desolder the wires using a desoldering wick and a soldering iron. Refer to the soldering page below.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Will this work on damaged cord near the end of hair dryer? The hair dryer is great shape just the cord that needed to be stripped to get rid of damaged part then cut then wired again.
