Zum Hauptinhalt wechseln
Halloween Witch Doctor Dancing Dog Broken Gear Replacement
Alan Nishioka
Alan Nishioka und eine weitere beteiligte Person
Zuletzt aktualisiert am July 26, 2024
Keine Schätzung
Mittel
Anleitung eines Community-Mitglieds
This plush toy dances and flaps it's ears to the witch doctor song. I replaced a gear to make it flap its ears again. I didn't think it could be fixed so I am writing this up.
  1. Halloween Witch Doctor Dancing Dog Broken Gear Replacement, Remove blind stitch to access mechanism.: Schritt 1, Bild 1 von 1
    • The bottom plate is removable, but doesn't give you access to the mechanism.
    • Blind stitch looks different from other seams in fabric.
  2. Halloween Witch Doctor Dancing Dog Broken Gear Replacement, Remove ear mechanism: Schritt 2, Bild 1 von 2 Halloween Witch Doctor Dancing Dog Broken Gear Replacement, Remove ear mechanism: Schritt 2, Bild 2 von 2
    • If you look closely at gear, you can see a small crack
    • I bought an assortment of plastic gears from Amazon because I wasn't sure of the size. https://www.amazon.com/gp/product/B075QY...
    • I ending up using an 8 tooth, 2mm shaft, 0.5 modulus gear. That is, an 82A white plastic gear.
Abschluss
Here is a video of it working again!
https://www.youtube.com/shorts/AESLgu-wI...
Alan Nishioka
3.507 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 58
