Zum Hauptinhalt wechseln
Hannspree Hannspad SN1AT71 Back Panel Replacement
matthew vandeventer
matthew vandeventer und 9 weitere Mitwirkende
Zuletzt aktualisiert am January 5, 2021
5 Minuten
Leicht
The Hannspad has a deceptive back panel that will not separate. Don't lose hope. This is not the real back panel, it is just there for aesthetics. The actual way to take the back panel off is at the seam around the edge of the screen. Follow these steps to protect your screen and easily take the back panel off your Hannspad.
Was du brauchst
Werkzeuge
  1. Hannspree Hannspad SN1AT71 Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Back Panel Replacement: Schritt 2, Bild 1 von 2 Hannspree Hannspad SN1AT71 Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Back Panel Replacement: Schritt 3, Bild 1 von 1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Back Panel Replacement: Schritt 4, Bild 1 von 2 Hannspree Hannspad SN1AT71 Back Panel Replacement: Schritt 4, Bild 2 von 2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Back Panel Replacement: Schritt 5, Bild 1 von 2 Hannspree Hannspad SN1AT71 Back Panel Replacement: Schritt 5, Bild 2 von 2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Colorado Springs, Team 9-4, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-4, Panko Spring 2015
UCCS-PANKO-S15S9G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 2,473
