Zum Hauptinhalt wechseln
HoMedics TotalComfort UHE-CM18 Oil Tray Replacement
Johny
Johny und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 29, 2023
1 Minute
Sehr einfach
If your humidifier seems to be leaking from the oil tray, follow this guide to access the oil tray. This guide is an easy-to-follow process of how to remove the oil tray for a simple replacement. For this guide, there are no tools needed other than your own hands.
  1. HoMedics TotalComfort UHE-CM18 Oil Tray Replacement, Oil Tray: Schritt 1, Bild 1 von 1
    • Lift up the water tank and separate it from the humidifier.
  2. HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: Schritt 2, Bild 1 von 3 HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: Schritt 2, Bild 2 von 3 HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: Schritt 2, Bild 3 von 3
    • Use your finger to push in the oil tray to extend it out of its slot.
    • Pull the oil tray out.
  3. HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: Schritt 3, Bild 1 von 2 HoMedics TotalComfort UHE-CM18 Oil Tray Replacement: Schritt 3, Bild 2 von 2
    • Remove the cotton oil pad before replacing the oil tray.
Abschluss
Johny
557 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 68
