Zum Hauptinhalt wechseln
Holmes Blizzard Fan Oscillation Gear Replacement
Mike Bolton
Mike Bolton und eine weitere beteiligte Person
Zuletzt aktualisiert am August 31, 2016
20 Minuten
Leicht
Anleitung eines Community-Mitglieds
In this guide, you will learn how to dissasemble the majority of the Blizzard fan. By following these easy steps, you can clean, service, or replace several components of this fan.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Holmes Blizzard Fan Oscillation Gear Replacement, Front Cage Removal: Schritt 1, Bild 1 von 3 Holmes Blizzard Fan Oscillation Gear Replacement, Front Cage Removal: Schritt 1, Bild 2 von 3 Holmes Blizzard Fan Oscillation Gear Replacement, Front Cage Removal: Schritt 1, Bild 3 von 3
    • Using a Phillips #2 Screwdriver, remove the 3 screws located on the back of the fan cage.
    • Next, loosen the screw located on the bottom of the fan.
    • The bottom screw does not need to be removed, but only loosened about 3 or 4 turns.
    • The front of the fan's cage is now able to be removed by prying the front away from the back.
  2. Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 2, Bild 1 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 2, Bild 2 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 2, Bild 3 von 3
    • Using a 7 mm socket and wrench, remove the 2 nuts that are behind the fan blades.
    • There is a washer located behind each nut. Be sure not to lose these.
  3. Holmes Blizzard Fan Oscillation Gear Replacement, Remove the Oscillation Button Screw: Schritt 3, Bild 1 von 2 Holmes Blizzard Fan Oscillation Gear Replacement, Remove the Oscillation Button Screw: Schritt 3, Bild 2 von 2
    • On the top of the fan, there is a screw fastening the oscillation button to the gear train within the housing. Remove this screw with the Phillips #0 Screwdriver.
  4. Holmes Blizzard Fan Oscillation Gear Replacement, Housing Assembly Removal: Schritt 4, Bild 1 von 2 Holmes Blizzard Fan Oscillation Gear Replacement, Housing Assembly Removal: Schritt 4, Bild 2 von 2
    • The on/off and fan speed nob can be removed by simply pulling it away from the main housing.
  5. Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 5, Bild 1 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 5, Bild 2 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 5, Bild 3 von 3
    • Remove the 2 screws holding the clear plastic plate in place with a Phillips #2 Screwdriver.
    • The plate is now free and can be taken out by hand.
  6. Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 6, Bild 1 von 2 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 6, Bild 2 von 2
    • The motor switch is also free and can be removed by hand to reveal a screw holding the housing assembly in place.
    • Be sure not to damage the wires on the switch during removal. While you do not need to be overly gentle during this step, excessive force could cause the wires to be pulled out.
  7. Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 7, Bild 1 von 2 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 7, Bild 2 von 2
    • Remove the screw that holds the housing assembly in place by using a Phillips #2 Screwdriver.
  8. Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 8, Bild 1 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 8, Bild 2 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 8, Bild 3 von 3
    • The housing assembly can now be pulled off and pushed to the side to reveal the fan motor and gear train.
    • The oscillation button the was unscrewed earlier will fall out of the housing assembly.
  9. Holmes Blizzard Fan Oscillation Gear Replacement, Oscillation Gear Removal: Schritt 9, Bild 1 von 2 Holmes Blizzard Fan Oscillation Gear Replacement, Oscillation Gear Removal: Schritt 9, Bild 2 von 2
    • Remove the 2 screws fastening the lid on the oscillation gear housing with a Flathead Screwdriver.
  10. Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 10, Bild 1 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 10, Bild 2 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 10, Bild 3 von 3
    • Using your thumb, the lid can easily be popped off to reveal the oscillation gear.
  11. Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 11, Bild 1 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 11, Bild 2 von 3 Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 11, Bild 3 von 3
    • The oscillation gear is removed by pressing it up from the bottom.
  12. Holmes Blizzard Fan Oscillation Gear Replacement: Schritt 12, Bild 1 von 1
    • The oscillation gear has been removed and fresh grease can be applied or it can be replaced.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Mike Bolton
570 Reputation
2 Anleitungen geschrieben
Ein Kommentar
Do you know where the oscillation gear can be purchased?
Keith Beba - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 30
Insgesamt: 3,340
