Zum Hauptinhalt wechseln
Holmes box fan motor replacement
Max Cossalter
Max Cossalter und eine weitere beteiligte Person
Zuletzt aktualisiert am October 29, 2015
Keine Schätzung
Leicht
This is a very simple guide that will help you dissasemble and replace the motor of your Holmes box fan, this process is easy and it only requires a screwdriver and a new motor to install.
Was du brauchst
Ersatzteile
Werkzeuge
  1. Holmes box fan motor replacement, Motor: Schritt 1, Bild 1 von 3 Holmes box fan motor replacement, Motor: Schritt 1, Bild 2 von 3 Holmes box fan motor replacement, Motor: Schritt 1, Bild 3 von 3
    • The first step is to make sure you unplug your fan from the outlet.
    • Make sure you also unplug the power cord from the back of the fan.
  2. Holmes box fan motor replacement: Schritt 2, Bild 1 von 2 Holmes box fan motor replacement: Schritt 2, Bild 2 von 2
    • Now that your fan is unplugged, lay it flat with the brand label facing upward.
    • Next is to remove the front cover.
    • Remove the six screws from the perimeter of the cover in order to remove the front cover.
  3. Holmes box fan motor replacement: Schritt 3, Bild 1 von 2 Holmes box fan motor replacement: Schritt 3, Bild 2 von 2
    • Next is the back cover.
    • Flip over the fan so you have access to these six screws.
    • Remove the six screws from the perimeter of the cover in order to remove the back cover.
  4. Holmes box fan motor replacement: Schritt 4, Bild 1 von 1
    • Remove these four screws in order to remove the motor and fan blades from the housing.
  5. Holmes box fan motor replacement: Schritt 5, Bild 1 von 1
    • The housing should now be able to lift away from the motor and fan blade.
  6. Holmes box fan motor replacement: Schritt 6, Bild 1 von 3 Holmes box fan motor replacement: Schritt 6, Bild 2 von 3 Holmes box fan motor replacement: Schritt 6, Bild 3 von 3
    • The next step is to remove the mounts that held the motor to the housing.
    • Remove these four screws to remove the mounts.
  7. Holmes box fan motor replacement: Schritt 7, Bild 1 von 2 Holmes box fan motor replacement: Schritt 7, Bild 2 von 2
    • Now you are able to remove the motor from the fan blades.
    • Be careful, if you used your fan recently the motor may be quite hot.
  8. Holmes box fan motor replacement: Schritt 8, Bild 1 von 1
    • Now you can insert your new motor and you are done!
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 15-4, Green Fall 2015 Mitglied von Cal Poly, Team 15-4, Green Fall 2015
CPSU-GREEN-F15S15G4
4 Mitglieder
4 Anleitungen geschrieben
5 Kommentare
Where might one find a replacement motor for a older box fan
Chris Cook - Antwort
Also, I would like to know where to get a replacement motor, as shown in step 4.
Vince Doriean - Antwort
Great guide! Upon reassembling, I noticed that the center of the propeller touches the front grill where it says Holmes. Anyone know if they rub on each other by design?
Zeev - Antwort
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
applejack_ - Antwort
Also want to know where to find this kind of replacement motor?
Bridget Alice Alonso - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 13,000
