Homedics UHE-CMP15 Charging Cable Cleaning
Einleitung
Zu Schritt 1 der AnleitungIf the device is not charging, follow this guide to cleaning or replacing the charging cable. You will need a spudger and a spare type-c charging cable on hand.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Check the USB port/both ends of the charging cable for dust or grime buildup.
Clear out any buildup carefully with a plastic tool, never metal.
Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
Try the charger again, you should see a red LED indicator if the device is charging.
A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
Purchase a replacement type-c charger or use another charger you already own to test again.
If this guide does not solve your charging problem, check out the battery replacement guide instead.
