Honeywell HY-204 Fan Blades Replacement
Einleitung
Zu Schritt 1 der AnleitungAfter removing the outer casing, replacing the fan blades is quick and easy! You would want to use this guide to replace the broken part or clean dirty blades.
Was du brauchst
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
