Zum Hauptinhalt wechseln
Honeywell HY-204 Fan Motor Replacement
Armando Jacob Espinoza
Armando Jacob Espinoza und 2 weitere Mitwirkende
Zuletzt aktualisiert am December 19, 2014
15 - 20 Minuten
Mittel
This guide will walk you through the removal of your fan motor. It should be fairly easy, although you will need to crimp the wires to remove the motor.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Honeywell HY-204 Fan Motor Replacement, Case: Schritt 1, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement, Case: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Motor Replacement: Schritt 2, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement: Schritt 2, Bild 2 von 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Motor Replacement, Fan Blades: Schritt 3, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement, Fan Blades: Schritt 3, Bild 2 von 2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Motor Replacement: Schritt 4, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement: Schritt 4, Bild 2 von 2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
  5. Honeywell HY-204 Fan Motor Replacement, Fan Motor: Schritt 5, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement, Fan Motor: Schritt 5, Bild 2 von 2
    • Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
    • Once the screws are removed, lift the motor off its base.
  6. Honeywell HY-204 Fan Motor Replacement: Schritt 6, Bild 1 von 2 Honeywell HY-204 Fan Motor Replacement: Schritt 6, Bild 2 von 2
    • Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
    • While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 10-40, Amido Fall 2014 Mitglied von Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
Where do you purchase the replacement fan motors from?
mattb - Antwort
Do you know where I can find the fan motor replacement?
Dave Smith - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 6,638
