Honeywell HY-204 Febreze Dial Replacement
Einleitung
Zu Schritt 1 der AnleitungIf you are having trouble with your Febreze scent settings, and you are sure that your scent cartridge is full, this is the guide for you! This guide will walk you through replacing the Febreze settings dial. Although this is a quick process, you need to be careful not to accidentally separate the wires from the dial.
Was du brauchst
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
Remove the two 3mm Phillips #0 screws from the back of the black dial box.
Pull the dial carefully, but forcefully, straight away from the black dial box. Do not twist the dial button while removing it.
