Zum Hauptinhalt wechseln
Honeywell HYF260BV2 Main Board Replacement
Joshua Moreno
Joshua Moreno und eine weitere beteiligte Person
Zuletzt aktualisiert am January 7, 2025
30 - 50 Minuten
Mittel
This guide shows a step-by-step process for removing a broken, old, or non-functional main board for a Honeywell Quietset Tower Fan HYF260BV2 and replacing it with a new one.
Safety Tips:
  • Unplug your fan before doing anything.
  • Wear a mask if your fan is very dusty.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Honeywell HYF260BV2 Main Board Replacement, Main Board: Schritt 1, Bild 1 von 2 Honeywell HYF260BV2 Main Board Replacement, Main Board: Schritt 1, Bild 2 von 2
    • Unplug your fan and place it on its side.
    • Twist the red plastic piece off from the bottom.
    • Carefully detach the base from the fan to expose the screws located at the bottom of the fan.
  2. Honeywell HYF260BV2 Main Board Replacement: Schritt 2, Bild 1 von 3 Honeywell HYF260BV2 Main Board Replacement: Schritt 2, Bild 2 von 3 Honeywell HYF260BV2 Main Board Replacement: Schritt 2, Bild 3 von 3
    • Use a TORX Security TR15 screwdriver to unscrew the three 12 mm screws near the bottom of the fan.
  3. Honeywell HYF260BV2 Main Board Replacement: Schritt 3, Bild 1 von 3 Honeywell HYF260BV2 Main Board Replacement: Schritt 3, Bild 2 von 3 Honeywell HYF260BV2 Main Board Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove four 12 mm screws on the head of the fan.
  4. Honeywell HYF260BV2 Main Board Replacement: Schritt 4, Bild 1 von 3 Honeywell HYF260BV2 Main Board Replacement: Schritt 4, Bild 2 von 3 Honeywell HYF260BV2 Main Board Replacement: Schritt 4, Bild 3 von 3
    • Use a heavy-duty spudger or opening tool to release the tabs securing the front and back of the fan, then gently pry them apart.
    • Do this gently because you could break the connectors for the back of the fan.
  5. Honeywell HYF260BV2 Main Board Replacement: Schritt 5, Bild 1 von 1
    • Pull off the back of the fan and set it aside.
    • Dust the inside of the fan if it is needed.
    • Be careful when dusting and ensure nothing is knocked out of place.
  6. Honeywell HYF260BV2 Main Board Replacement: Schritt 6, Bild 1 von 3 Honeywell HYF260BV2 Main Board Replacement: Schritt 6, Bild 2 von 3 Honeywell HYF260BV2 Main Board Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws at the head of the fan.
    • Remove the two larger 14 mm Phillips #1 screws located below.
    • Remove the two 10 mm Phillips #1 screws located between the 14 mm screws.
  7. Honeywell HYF260BV2 Main Board Replacement: Schritt 7, Bild 1 von 1
    • Pull the gray cover from the fan to reveal the main board.
  8. Honeywell HYF260BV2 Main Board Replacement: Schritt 8, Bild 1 von 1
    • Carefully hold the edges of the main board and slowly pull it out.
  9. Honeywell HYF260BV2 Main Board Replacement: Schritt 9, Bild 1 von 2 Honeywell HYF260BV2 Main Board Replacement: Schritt 9, Bild 2 von 2
    • Unplug the main board.
    • Follow the cables connected to the board to the bottom of the fan.
  10. Honeywell HYF260BV2 Main Board Replacement: Schritt 10, Bild 1 von 2 Honeywell HYF260BV2 Main Board Replacement: Schritt 10, Bild 2 von 2
    • Unplug the connector to disconnect the bundle of wires.
    • Use scissors to cut the zip tie that secures the wires.
    • Be careful when you cut the zip tie so that you don't accidentally cut the wires.
  11. Honeywell HYF260BV2 Main Board Replacement: Schritt 11, Bild 1 von 1
    • Pull the wires up and slide them out of the fan to replace the main board with a new one.
Abschluss
Joshua Moreno
193 Reputation
1 Anleitung geschrieben
Austin Community College, Team 28-7, Watkins Fall 2024 Mitglied von Austin Community College, Team 28-7, Watkins Fall 2024
AUSTINCC-WATKINS-F24S28G7
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 45
