Zum Hauptinhalt wechseln
Hoover Power Path Deluxe FH50951 Belt Replacement
Karen Aldakhel
Karen Aldakhel und eine weitere beteiligte Person
Zuletzt aktualisiert am January 14, 2025
5 Minuten
Mittel
Empfohlene Anleitung von Studierenden
If your Hoover Power Path Deluxe FH50951 isn’t cleaning well or the brush roll isn’t spinning, the belt may need replacing. The belt powers the brush roll, which is key for effective carpet cleaning. This simple fix is similar to replacing the brush roll and can restore your vacuum’s performance. You should compare the old belt to the new one to ensure they match in size and type. Using the wrong belt can affect performance.
Was du brauchst
Werkzeuge
  1. Hoover Power Path Deluxe FH50951 Belt Replacement, Brush Roll: Schritt 1, Bild 1 von 3 Hoover Power Path Deluxe FH50951 Belt Replacement, Brush Roll: Schritt 1, Bild 2 von 3 Hoover Power Path Deluxe FH50951 Belt Replacement, Brush Roll: Schritt 1, Bild 3 von 3
    • Remove the four 18.6 mm screws labeled 1-4 using a Phillips #1 screwdriver.
    • Remove the piece that was being held down by those screws.
  2. Hoover Power Path Deluxe FH50951 Belt Replacement: Schritt 2, Bild 1 von 3 Hoover Power Path Deluxe FH50951 Belt Replacement: Schritt 2, Bild 2 von 3 Hoover Power Path Deluxe FH50951 Belt Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 18.6 mm screws with arrows listing 5-8 using a Phillips #1 screwdriver.
    • Remove the wheel assembly on the left side of the vacuum.
    • You may need a longer Phillips #1 screwdriver for screw #7.
  3. Hoover Power Path Deluxe FH50951 Belt Replacement: Schritt 3, Bild 1 von 1
    • Lift up the belt to give enough slack to allow the brush roll to come out.
    • While lifting the belt, pull/push upward away from the cleaner to pop it out.
    • It may seem like the brush rolls wont come out but just put more force into it.
  4. Hoover Power Path Deluxe FH50951 Belt Replacement, Belt: Schritt 4, Bild 1 von 2 Hoover Power Path Deluxe FH50951 Belt Replacement, Belt: Schritt 4, Bild 2 von 2
    • Gently slide the belt off of the motor shaft and lift it out of the vacuum.
    • Loop one end of the new belt around the motor shaft, making sure it sits securely in the groove.
    • Ensure the belt is securely placed in the correct slot on both the motor shaft and the brush roll. A loosely installed or improperly positioned belt can slip, break, or prevent the brush roll from spinning correctly, potentially damaging your vacuum. Double-check that the belt is aligned and tensioned properly before reassembling the vacuum.
Abschluss
Karen Aldakhel
173 Reputation
1 Anleitung geschrieben
Cuesta, Team 60-1, Krynen Fall 2024 Mitglied von Cuesta, Team 60-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 9
Insgesamt: 45
