Zum Hauptinhalt wechseln
How to Darn a Sock
How to Darn a Sock
justinHo910
justinHo910 und 2 weitere Mitwirkende
Zuletzt aktualisiert am May 1, 2024
5 - 15 Minuten
Leicht
Umwege erhöhen die Ortskenntnis
Benötigt Bessere Bilder
If you have a hole in your sock and want to fix it, this guide will help repair it through a simple method called darning.
Darning a hole in a sock provides a different outcome than simply sewing up the hole. When you darn a sock, it acts as a replacement for the missing fabric. So, if you have suitable thread types, you can create cool patchwork socks.
A darning mushroom is one of the tools listed. These can be found on Amazon or whichever website you use to purchase goods. If you do not have a darning mushroom or wish to avoid purchasing one, substitutes include tennis balls, light bulbs, or, like in my guide, a water bottle. Essentially, you will need an object inside the sock to stretch out the hole.
  1. How to Darn a Sock, How to Darn a Sock: Schritt 1, Bild 1 von 2 How to Darn a Sock, How to Darn a Sock: Schritt 1, Bild 2 von 2
    • Insert a darning egg (or substitute object) into the sock until the hole is stretched out.
  2. How to Darn a Sock: Schritt 2, Bild 1 von 2 How to Darn a Sock: Schritt 2, Bild 2 von 2
    • Sew a running stitch around the hole to reinforce it.
    • To make a running stitch, move your needle in and out of the sock a fixed distance apart.
    • The needle is sharp; use caution and avoid poking your hand.
  3. How to Darn a Sock: Schritt 3, Bild 1 von 2 How to Darn a Sock: Schritt 3, Bild 2 von 2
    • Start a stitch from one side of the hole, about ½” to ⅛” away. Connect one side of the hole to the other using the thread.
    • Run parallel stitches until the hole is fully covered.
  4. How to Darn a Sock: Schritt 4, Bild 1 von 2 How to Darn a Sock: Schritt 4, Bild 2 von 2
    • Rotate your sock 90 degrees, then repeat step 4 to create a patch.
  5. How to Darn a Sock: Schritt 5, Bild 1 von 2 How to Darn a Sock: Schritt 5, Bild 2 von 2
    • Weave the extra thread into the sock's fabric, then cut the needle away from the thread.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
justinHo910
145 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Mitglied von CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 36
Letzte 30 Tage: 189
Insgesamt: 842
