How to Fix a Broken Plastic Figurine
Einleitung
Zu Schritt 1 der AnleitungCollectable figurines can develop defects or suffer damage over time. To address this issue, we have come up with a quick and easy solution to repairing a broken plastic figurine. Using a hot glue gun as a heat source, without the use of glue, you can restore your collectable figurines back to its pristine condition.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Wipe down the figurine carefully with an alcohol wipe, focusing on the broken areas.
Plug in the hot glue gun and let it heat up.
Straighten out the paperclip.
Place the paperclip in the tip of the hot glue gun in order to heat the metal.
Allow the paperclip to heat up for 5 minutes.
Remove the paperclip from the glue gun.
Use the heated paperclip to scrape away excess material from one part of the figurine.
Firmly press the glue gun's heated tip into the other part of the figurine to melt the surrounding plastic for smoother placement.
Align the broken pieces together carefully.
Press the two pieces together.
Hold together tightly for a minute to bond the pieces.
Eine weitere Person hat diese Anleitung absolviert.
