How to Repair a Portable Fan
Einleitung
Zu Schritt 1 der AnleitungThis fix will restore your fan's original power and quiet operation. This fix does not require new parts, but does require a #1 Phillips head screwdriver, an 8mm wrench or socket, and a medium or low viscosity lubricant.
Was du brauchst
Loosen the 4 phillips screws around the rim and remove the front of the cage
Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
To reassemble your device, follow these steps in reverse order.
5 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
Mine did the same
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
