How to Replace a Ceiling Fan Lighting Circuit Power-Limiting Device
Einleitung
Zu Schritt 1 der AnleitungFaulty power-limiting devices are often the cause of ceiling fan lighting issues. These issues may include lights dimming, flickering, or not illuminating at all.
These devices are simple to replace, but replacements can be difficult to find. Luckily, these devices can be removed and your ceiling fan/lights operated safely, provided fan manufacturer recommendations for light bulbs are adhered to.
Power-limiting devices do just that—limit power. You may notice a slight uptick in your energy bill if you use your fan often.
This guide will show how to replace or remove the power-limiting device (Model No. 98480X; Part No. 98480-02) in the lighting circuit of a Hunter Baker Street Model #20713 ceiling fan.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Shut off electrical power to the ceiling fan by switching the appropriate circuit breaker to the “OFF” position.
Use a Phillips #1 screwdriver to remove the three 12 mm screws to separate the lower switch housing from the upper switch housing. .
Pull the lower switch housing straight down, with minimal force, to separate the lower and upper switch housing.
Unclip the pigtail connector that attaches the wires from the lower switch housing to the upper switch housing.
To remove the power-limiting device (Part No. 98480-02) from the circuit:
Loosen and remove the twist-on wire connectors.
Disconnect the terminal connectors.
Remove the terminal connectors disconnected in the previous step from the wires attached to the switch housing.
After cutting, strip off about two inches of the insulation in preparation for wire termination.
Reinstall the light pull-switch into the circuit.
Terminate the hot and neutral wires with the appropriate wire bundle using twist-on wire connectors.
Replace the three 12 mm screws securing the lower switch housing to the upper switch housing with a Phillips #1 screwdriver.
Restore electrical power to the ceiling fan by positioning the appropriate circuit breaker to the “ON” position.
The lamp fixture on your ceiling fan should now light without issue!
Eine weitere Person hat diese Anleitung absolviert.
