Zum Hauptinhalt wechseln
How to Restring a Hoodie
Victoria Longa
Victoria Longa und 2 weitere Mitwirkende
Zuletzt aktualisiert am June 10, 2021
5 - 15 Minuten
Sehr einfach
Empfohlene Anleitung von Studierenden
The strings of a hoodie can often move around, become uneven, or fall out of the hoodie. This is something that can ruin one’s favorite hoodie but it is easy to fix.
This fix uses a safety pin to move the string through the hoodie to fix this common occurrence and make the strings even once again. Be careful though, during steps 2 and 5 using a safety pin can cause injury.
It is recommended that the hoodie and string are washed before beginning this repair. This ensures that no dirt gets carried and stuck in the hole of the hoodie. It is also best if someone is not wearing the hoodie while repairing it so it is easier to move the safety pin through the hoodie.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. How to Restring a Hoodie, How to Restring a Hoodie: Schritt 1, Bild 1 von 2 How to Restring a Hoodie, How to Restring a Hoodie: Schritt 1, Bild 2 von 2
    • Remove the string from the hoodie.
  2. How to Restring a Hoodie: Schritt 2, Bild 1 von 3 How to Restring a Hoodie: Schritt 2, Bild 2 von 3 How to Restring a Hoodie: Schritt 2, Bild 3 von 3
    • Pin the safety pin to one end of the string.
    • Safety pin can cause injury if handled incorrectly.
  3. How to Restring a Hoodie: Schritt 3, Bild 1 von 2 How to Restring a Hoodie: Schritt 3, Bild 2 von 2
    • Insert the end of the string with the safety pin into one of the holes of the hoodie.
  4. How to Restring a Hoodie: Schritt 4, Bild 1 von 1
    • Pinch the fabric to help the safety pin move through the hoodie.
  5. How to Restring a Hoodie: Schritt 5, Bild 1 von 1
    • Straighten out the fabric while holding the safety pin.
  6. How to Restring a Hoodie: Schritt 6, Bild 1 von 3 How to Restring a Hoodie: Schritt 6, Bild 2 von 3 How to Restring a Hoodie: Schritt 6, Bild 3 von 3
    • Continue pinching and straightening the fabric while holding onto the safety pin to move the string through the hoodie.
    • Do this until the safety pin reaches the hole on the other side of the hoodie.
  7. How to Restring a Hoodie: Schritt 7, Bild 1 von 1
    • Pull the string end with the safety pin completely out of the hole.
  8. How to Restring a Hoodie: Schritt 8, Bild 1 von 1
    • Remove the safety pin from the string.
Abschluss
After restringing the hoodie, you can wear it without fear of uneven or missing strings.
Victoria Longa
157 Reputation
1 Anleitung geschrieben
Marist, Team S1-G3, Chaterdon Spring 2021 Mitglied von Marist, Team S1-G3, Chaterdon Spring 2021
MARS-CHATERDON-S21S1G3
2 Mitglieder
Ein Kommentar
Great tutorial but I have two comments/suggestions:
First, when inserting the pin into the hoodie I think it’d be even easier to pass the pin through the hoodie if the pin was inserted HEAD FIRST - meaning that the thicker, curved head should enter first. I run electrical wiring using a snake with a looped end. We often have to wrap electrical tape around the part of the looped end of the snake so that any open edges don’t catch on anything as the snake is being pulled. Similar concept applies here. Putting the pin in head first would probably facilitate it passing through more easily.
Second suggestion is to cut up a wire hanger and create a make shift snake/pull. Run it through the channel of the hoodie out the other end. Once through, loop one end of wire, put in string and tie a knot larger than the loop, tape any rough edges with electrical tape, and slowly pull through. Crochet needles or some other such knitting/crocheting tools might work well too.
Mark DiRollo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 20
Letzte 30 Tage: 128
Insgesamt: 14,113
