Zum Hauptinhalt wechseln
How to unclog/teardown an Ambiano CM-202
James Van Damme
James Van Damme und 2 weitere Mitwirkende
Zuletzt aktualisiert am July 23, 2024
30 - 45 Minuten
Mittel
Anleitung eines Community-Mitglieds
Aldi sells these Keurig-type coffeemakers for about $29. After running ours for 4 months, it suddenly starting dispensing a quarter cup of coffee in dribbles. Descaling with vinegar was no help. It was time for a teardown.
Was du brauchst
    • First, unplug the unit and dump out all the water. Find a hospitable teardown area, and suitable storage for screws and parts.
  1. How to unclog/teardown an Ambiano CM-202, Take off the top cover: Schritt 2, Bild 1 von 1
    • Remove the two screws that hold the back end of the top cover. Unsnap the front of the cover with a spudger or screwdriver. Note the two underneath which help hold the back shell on.
  2. How to unclog/teardown an Ambiano CM-202, Remove the pipe from dispenser head: Schritt 3, Bild 1 von 1
    • In the center you see the dispenser that punctures your K cup, The output pipe comes into the end of this from the heater (removed here). Reach in with pliers and squeeze the hose clamp ends to release it, and slide it down so you can pull the hose off the hose barb on the head. The switch on the bottom right closes when the lever is down.
  3. How to unclog/teardown an Ambiano CM-202, Attempt to clear the clog: Schritt 4, Bild 1 von 1
    • The top end of this pipe is right at the dispenser head right angle bend. Clogs are likely here. If you are very lucky, you can get them out from the head end without tearing apart the rest of the unit. Plug it in and expansion of the hot water may pump it out. You can slip a hose over it or just dump it into the bottom of the dispenser head.
    • If this works, just reattach the hose and put the cover and 2 screws back in, and you've earned a cup of coffee. If you are unsuccessful, continue with disassembly. The bracket with the two holes doesn't attach to anything.
  4. How to unclog/teardown an Ambiano CM-202, Take off the bottom plate: Schritt 5, Bild 1 von 1
    • Remove the 7 screws on the bottom metal plate.
  5. How to unclog/teardown an Ambiano CM-202, Pump maintenance: Schritt 6, Bild 1 von 1
    • Working on the pump or internal pipes is impossible without removing the back shell, as seen here.
  6. How to unclog/teardown an Ambiano CM-202, Detach back shell: Schritt 7, Bild 1 von 1
    • Remove the 5 screws (shown loose here) that attach the outside shell to the bottom. Remove the two at the top which were under the top cover.
    • Use a spudger or screwdriver to pry the back shell off of the front. the back shell presses inward at the catches to release them.
  7. How to unclog/teardown an Ambiano CM-202, Check for contaminants: Schritt 9, Bild 1 von 1
    • Check all the piping for clogs or contaminants. Release the hose clamps and pull the pipes off if needed.
  8. How to unclog/teardown an Ambiano CM-202, Clean inlet pipe: Schritt 10, Bild 1 von 1
    • Clean out the inlet pipe adapter if needed, by releasing the clamp. This item serves no apparent purpose, but could clog up, rendering the device inoperative. Perhaps it is a Planned Obsolescence Filter.
  9. How to unclog/teardown an Ambiano CM-202, Output pipe and thermostat: Schritt 11, Bild 1 von 1
    • the wires at top are the thermostat for the heater. The bottom, black/white wires are a thermal overload which blows if the heater gets way too hot. This is a common failure item and are replaceable. Be sure the thermostat works first. The spring in the output pipe keeps the pipe from kinking, and just falls out if you remove the pipe.
  10. How to unclog/teardown an Ambiano CM-202, Clean out the reservoir filter: Schritt 12, Bild 1 von 1
    • This filters out stray coffee grounds and other large debris. Unscrew the two screws and clean it out if necessary. You can also just clean it with a small brush without removing it, the dirt will be on the outside. Rinse out the debris and dump it.
  11. How to unclog/teardown an Ambiano CM-202, Control board: Schritt 13, Bild 1 von 1
    • There are two timers which simply adjust the pump time for different volumes of coffee. If flow is restricted, volume delivered will be greatly reduced. There are no other complicated level sensors like other coffeemakers.
  12. How to unclog/teardown an Ambiano CM-202, Reassemble: Schritt 14, Bild 1 von 1
    • Reassembly is a backwards disassemble. It's easiest to attach the inlet pipe to the pump as shown here, then reattach the top of the pipe up to the reservoir.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 43
Insgesamt: 1,223
