Huawei Honor 6x Rear Camera Replacement
Einleitung
Zu Schritt 1 der AnleitungIf the camera of your Huawei Honor 6x is inoperable and the problem is not due to a cracked cover, the rear camera will need to be replaced. Removing the broken camera assembly is simple and easy after opening the phone.
Was du brauchst
Insert the SIM Card Eject Tool into the SIM card tray hole.
Press the eject tool into the hole until the tray clicks open.
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Slide the opening tool or spudger along the bottom of the phone and around the edge.
Once three sides of the screen are detached, pry the phone apart using two hands.
Pry the two connectors off by wedging a spudger, or your finger, underneath the connector.
2 weitere Personen haben diese Anleitung absolviert.
