Huawei Ideos S7 Slim Mini-USB port Replacement
Einleitung
Zu Schritt 1 der AnleitungThis will enable the user to correct any problems with the mini-usb port if it has malfunctioned.
Was du brauchst
Place the tablet on a flat clear surface to keep the screen safe.
Slide the larger portion of the back cover off the tablet.
This will reveal the battery.
Using a plastic opening tool, pry off the top cover casing gently by moving the tool along all three sides.
With a T5 hexagonal head, remove the nine black 2.5 mm torx screws. Place them carefully aside on the magnetic mat.
Using a plastic opening tool, pry off the back casing gently on each side of the tablet.
Using a Phillips #00 screwdriver, remove the following screws:
Four 5mm wide grey Phillips screws on the logic board.
Seven 3mm small grey Phillips screws (four on one side, three on the other) from the black side casing.
Disconnect the five cables connected to the logic board and then carefully lift the logic board out of the casing.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Heat the solder to the mini-USB port.
Remove the melted solder using a solder sucker or desoldering braid.
Replace the old mini-USB port with a new one by attaching it using a new solder.
Let cool, then replace logic board in tablet.
Eine weitere Person hat diese Anleitung absolviert.
