Zum Hauptinhalt wechseln
Huawei MediaPad M3 Rear Camera Replacement
Was du brauchst
  1. Huawei MediaPad M3 Rear Camera Replacement, Display Assembly: Schritt 1, Bild 1 von 2 Huawei MediaPad M3 Rear Camera Replacement, Display Assembly: Schritt 1, Bild 2 von 2
    • Use a heat gun to heat the display. It may take up to 30 seconds.
    • Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
  2. Huawei MediaPad M3 Rear Camera Replacement: Schritt 2, Bild 1 von 2 Huawei MediaPad M3 Rear Camera Replacement: Schritt 2, Bild 2 von 2
    • Open the display carefully.
    • Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
  3. Huawei MediaPad M3 Rear Camera Replacement: Schritt 3, Bild 1 von 2 Huawei MediaPad M3 Rear Camera Replacement: Schritt 3, Bild 2 von 2
    • After removing the two screws, use your hand to take out the silver metal bracket.
  4. Huawei MediaPad M3 Rear Camera Replacement: Schritt 4, Bild 1 von 3 Huawei MediaPad M3 Rear Camera Replacement: Schritt 4, Bild 2 von 3 Huawei MediaPad M3 Rear Camera Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to disconnect the two ribbon cable connectors.
  5. Huawei MediaPad M3 Rear Camera Replacement: Schritt 5, Bild 1 von 2 Huawei MediaPad M3 Rear Camera Replacement: Schritt 5, Bild 2 von 2
    • Remove the display assembly from the device.
  6. Huawei MediaPad M3 Rear Camera Replacement, Front Camera: Schritt 6, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the six 3.0mm screws.
  7. Huawei MediaPad M3 Rear Camera Replacement: Schritt 7, Bild 1 von 1
    • Use your hand to remove the silver metal bracket.
  8. Huawei MediaPad M3 Rear Camera Replacement: Schritt 8, Bild 1 von 2 Huawei MediaPad M3 Rear Camera Replacement: Schritt 8, Bild 2 von 2
    • Use your hand to remove the two black plastic covers.
  9. Huawei MediaPad M3 Rear Camera Replacement: Schritt 9, Bild 1 von 3 Huawei MediaPad M3 Rear Camera Replacement: Schritt 9, Bild 2 von 3 Huawei MediaPad M3 Rear Camera Replacement: Schritt 9, Bild 3 von 3
    • Use a plastic opening tool to remove the front camera.
  10. Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: Schritt 10, Bild 1 von 3 Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: Schritt 10, Bild 2 von 3 Huawei MediaPad M3 Rear Camera Replacement, Rear Camera: Schritt 10, Bild 3 von 3
    • Disconnect and remove the camera from the motherboard.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 519
