Zum Hauptinhalt wechseln
Huawei MediaPad S7-301u Battery Replacement
Miguel Lugo
Miguel Lugo und 4 weitere Mitwirkende
Zuletzt aktualisiert am August 8, 2019
45 Minuten
Mittel
The battery is an essential part of the device. A battery that is in use for a long time can be worn out or malfunction. If you notice your battery drains fast or doesn’t charge at all, then you know that you have a bad battery that needs to be replaced. Another sign of a bad battery is a swollen or deformed battery. A swollen battery can be hazardous because it can leak dangerous chemicals. Always wear proper protection while handling batteries and follow the manufacturer's safety procedure.
The Huawei HB3G1H internal battery is the one that needs to be replace in this device. After the replacement; if it’s still not working, then the next step is to check other components of the device such as motherboard or any other wires that may be disconnected.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Huawei MediaPad S7-301u Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Huawei MediaPad S7-301u Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: Schritt 3, Bild 1 von 3 Huawei MediaPad S7-301u Battery Replacement: Schritt 3, Bild 2 von 3 Huawei MediaPad S7-301u Battery Replacement: Schritt 3, Bild 3 von 3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: Schritt 4, Bild 1 von 3 Huawei MediaPad S7-301u Battery Replacement: Schritt 4, Bild 2 von 3 Huawei MediaPad S7-301u Battery Replacement: Schritt 4, Bild 3 von 3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Miguel Lugo
598 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S11-G5, Passmore Fall 2017 Mitglied von USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 7,241
