Insignia NS-F12R6-SS Motor Housing Replacing
Einleitung
Zu Schritt 1 der AnleitungRemoving the motor housing provides access to all of the fan's internal workings.
Was du brauchst
Werkzeuge
Unplug your fan.
Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
Use your fingers to gently pull the power knob directly away from the motor housing.
Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
3 weitere Personen haben diese Anleitung absolviert.
