Zum Hauptinhalt wechseln
Insignia NS-F12R6-SS Upper Oscillation Gear Replacement
Hank
Hank und eine weitere beteiligte Person
Zuletzt aktualisiert am December 20, 2018
10 - 15 Minuten
Mittel
The oscillation gear swivels the head of the fan back and forth by translating power from the motor into the oscillation arm.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Front Cage: Schritt 1, Bild 1 von 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Front Cage: Schritt 1, Bild 2 von 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 2, Bild 1 von 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 3, Bild 1 von 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Fan Blade: Schritt 4, Bild 1 von 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 5, Bild 1 von 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Back Cage: Schritt 6, Bild 1 von 1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 7, Bild 1 von 1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Oscillation Button: Schritt 8, Bild 1 von 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Oscillation Button: Schritt 8, Bild 2 von 2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 9, Bild 1 von 1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Motor Housing: Schritt 10, Bild 1 von 1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 11, Bild 1 von 1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 12, Bild 1 von 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 12, Bild 2 von 2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 13, Bild 1 von 1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 14, Bild 1 von 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 14, Bild 2 von 2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 15, Bild 1 von 1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 16, Bild 1 von 1
    • Remove the small piece of paper hanging on the power button.
  17. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: Schritt 17, Bild 1 von 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: Schritt 17, Bild 2 von 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: Schritt 17, Bild 3 von 3
    • Using a Phillips #3 screwdriver, unscrew and remove the 7 mm long bolt and small washer fastening the yellow and green wire to the motor housing support.
  18. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 18, Bild 1 von 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 18, Bild 2 von 2
    • Using a Phillips #3 screwdriver unscrew the 13 mm long screw fastening the motor housing support to the oscillation gear box.
  19. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 19, Bild 1 von 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 19, Bild 2 von 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 19, Bild 3 von 3
    • Using a Phillips #3 screwdriver, unscrew the three 13 mm long screws fastening the grey plate to the top of the oscillation gear box.
    • Remove the grey cap covering the oscillation gear box.
  20. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 20, Bild 1 von 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: Schritt 20, Bild 2 von 2
    • Remove the upper oscillation gear.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Hank
1.142 Reputation
8 Anleitungen geschrieben
CSU Fullerton, Team S2-G1, Bruce Fall 2018 Mitglied von CSU Fullerton, Team S2-G1, Bruce Fall 2018
CSUF-BRUCE-F18S2G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 647
