Zum Hauptinhalt wechseln
Inspiron 17 5758 Hard Drive Replacement
Was du brauchst
  1. Inspiron 17 5758 Hard Drive Replacement, Remove battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over, battery facing you. Move the latch to the right, and grab the battery as it comes up.
  2. Inspiron 17 5758 Hard Drive Replacement, Remove hard drive cover: Schritt 2, Bild 1 von 1
    • Remove the two Philips screws securing the hard drive cover.
    • Use a spudger in the provided hole to pry the cover upwards.
  3. Inspiron 17 5758 Hard Drive Replacement, Remove hard drive caddy: Schritt 3, Bild 1 von 1
    • Remove the four Philips screws securing the hard drive caddy.
    • Remove the four screws from the hard drive caddy, and take the SATA connector off. You're done!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Joseph Sctbunio
7.075 Reputation
42 Anleitungen geschrieben
Ein Kommentar
I found it very straightforward to purchase a Kingston KC600 SSD drive, which includes an external caddy, then use the free Aomei cloning software to clone the existing drive, then follow this article to open up the Inspiron, remove the SATA drive and install the KC600 drive instead. Thanks! It had become unbearable slow running Windows 10 but now has another lease of life.
Imogen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 669
