Zum Hauptinhalt wechseln
Inspiron 7359 2-in-1 Fan Replacement
Dominique
Dominique und 4 weitere Mitwirkende
Zuletzt aktualisiert am December 22, 2020
10 Minuten
Mittel
Studierende im Gange!
Use this guide to replace the CPU fan in the Inspiron 7359 2-in-1.
The purpose of the CPU fan is to cool down the computer processor. This is accomplished by pulling hot air away from the processor.
The best way to tell if your CPU fan has stopped working is to look and listen. Check to see if the fan is rotating. If the fan is not moving it should be replaced immediately. You can also hear a working fan, especially if it running at top speed.
Also, know that most computers will shut down if they are too hot. If your computer is shutting down on a regular basis, it might be because it needs a new fan. To read more about this click here.
Changing the CPU fan is a three-step process. Each step includes easy to follow instructions and a photo that demonstrates what you need to do.
Note that you should remove the HDD before you start. This will make it easier to take out the fan. Removing the fan requires a gentle touch.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Inspiron 7359 2-in-1 Fan Replacement, Bottom Case: Schritt 1, Bild 1 von 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: Schritt 2, Bild 1 von 2 Inspiron 7359 2-in-1 Fan Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: Schritt 4, Bild 1 von 1
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: Schritt 5, Bild 1 von 1
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: Schritt 6, Bild 1 von 2 Inspiron 7359 2-in-1 Fan Replacement: Schritt 6, Bild 2 von 2
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: Schritt 7, Bild 1 von 2 Inspiron 7359 2-in-1 Fan Replacement, Fan: Schritt 7, Bild 2 von 2
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: Schritt 8, Bild 1 von 1
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
Abschluss
Dominique
251 Reputation
2 Anleitungen geschrieben
Gateway, Team S1-G3, Saknee Fall 2019 Mitglied von Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 20
Letzte 30 Tage: 21
Insgesamt: 496
