Zum Hauptinhalt wechseln
Kobo Glo E-reader USB Port Replacement
Laura Ahsmann
Laura Ahsmann und 2 weitere Mitwirkende
Zuletzt aktualisiert am September 11, 2023
45 Minuten
Mittel
Aufzählungszeichen!
Anleitung eines Community-Mitglieds
This manual is for repairing the USB port of your e-reader. It can be used for any type of e-reader, but some steps will be slightly different. This example uses the Kobo Glo HD. An iFixit set was used for this repair, together with a soldering station that enlarges the image under a camera. This is recommended because the parts are very small.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Kobo Glo E-reader USB Port Replacement, Remove the back panel and the screws.: Schritt 1, Bild 1 von 2 Kobo Glo E-reader USB Port Replacement, Remove the back panel and the screws.: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • Make sure to store the screws somewhere you won't loose them, like on your FixMat.
  2. Kobo Glo E-reader USB Port Replacement, Disconnect the ribbon cable: Schritt 2, Bild 1 von 1
    • All you have to do is lift the black locking arm that is keeping the ribbon cable in place. See picture.
  3. Kobo Glo E-reader USB Port Replacement, Remove the motherboard: Schritt 3, Bild 1 von 1
    • Carefully remove the motherboard from your e-reader.
  4. Kobo Glo E-reader USB Port Replacement, Check the voltage on all six motherboard pins: Schritt 4, Bild 1 von 1
    • Check the voltage of all six pins: if a pin shows no voltage level this probably means the pin is loose.
  5. Kobo Glo E-reader USB Port Replacement, Resolder the disconnected pin(s): Schritt 5, Bild 1 von 1
    • Use as much flux as possible (i.e. with the use of a flux marker).
    • A magnifying camera makes the job a lot easier.
    • Make sure that the pins are not touching each other.
  6. Kobo Glo E-reader USB Port Replacement, Put back the motherboard: Schritt 6, Bild 1 von 2 Kobo Glo E-reader USB Port Replacement, Put back the motherboard: Schritt 6, Bild 2 von 2
    • Carefully reassemble the parts.
  7. Kobo Glo E-reader USB Port Replacement, Final check: Schritt 7, Bild 1 von 1
    • Make sure that the e-reader functions properly before completely reassembling and closing it.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
nl en
100%
Hier starten ›
6 Kommentare
My on/off button stopped working. The kobo won't start.... Thank you!
E K - Antwort
I needed to see how the USB plug was aligned on the motherboard and your guide showed me exactly this. Since I am not able to solder I will ask someone else to do the job, but at least I know I tried my best. Thank you.
VooBee - Antwort
Where did you buy the replacement part from?
Techie -
Hello guys, two of the pins on my reader are broken and I can't find the exact micro usb b model to buy the replacement.
Do you recommend a website to get it from?
Thanks a lot for your help
Edu Insua - Antwort
There was one on Ebay
Test taaaa -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 57
Letzte 30 Tage: 191
Insgesamt: 7,321
