Zum Hauptinhalt wechseln
LG A275 Vibrator Replacement
Nathanael Knight
Nathanael Knight und eine weitere beteiligte Person
Zuletzt aktualisiert am May 25, 2018
10 Minuten
Mittel
In this guide, you will see how to take apart the LG-A275 in order to replace the phone's vibrator.
Was du brauchst
Werkzeuge
  1. LG A275 Vibrator Replacement, Battery: Schritt 1, Bild 1 von 2 LG A275 Vibrator Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the phone upside down so that the bottom of the back is facing you.
  2. LG A275 Vibrator Replacement, Remove cover: Schritt 2, Bild 1 von 2 LG A275 Vibrator Replacement, Remove cover: Schritt 2, Bild 2 von 2
    • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
  3. LG A275 Vibrator Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the battery from the device.
  4. LG A275 Vibrator Replacement, Vibrator: Schritt 4, Bild 1 von 3 LG A275 Vibrator Replacement, Vibrator: Schritt 4, Bild 2 von 3 LG A275 Vibrator Replacement, Vibrator: Schritt 4, Bild 3 von 3
    • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
    • Be careful when using the plastic opening tool not to brute force the phone open, the plastics are fragile.
  5. LG A275 Vibrator Replacement: Schritt 5, Bild 1 von 2 LG A275 Vibrator Replacement: Schritt 5, Bild 2 von 2
    • After separating the two plastic halves of the phone, take the plastic that does not have the motherboard attached to it. The plastic has a small yellow component with a lob-sided magnet within it. This is the vibrator of the phone, pull this piece out with your hand. This piece is free floating and will simply drop out.
Abschluss
To reassemble your device, follow these instructions in reverse order after placing in the new vibrator.
Nathanael Knight
181 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G1, Harley Spring 2018 Mitglied von IUPUI, Team S3-G1, Harley Spring 2018
IUPUI-HARLEY-S18S3G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 141
