Zum Hauptinhalt wechseln
LG Chocolate Keypad Replacement
Maci Miri
Maci Miri und 5 weitere Mitwirkende
Zuletzt aktualisiert am January 10, 2018
Keine Schätzung
Schwierig
Benötigt Bessere Bilder
Studierende im Gange!
Aufzählungszeichen!
Fehler in den Markups
Benötigt Mehr Bilder
Action Shots
Bessere Einleitung
Was du brauchst
Werkzeuge
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Mehr anzeigen …
  1. LG Chocolate Keypad Replacement, Battery: Schritt 1, Bild 1 von 2 LG Chocolate Keypad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Keypad Replacement, Back Cover: Schritt 2, Bild 1 von 1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Keypad Replacement: Schritt 3, Bild 1 von 3 LG Chocolate Keypad Replacement: Schritt 3, Bild 2 von 3 LG Chocolate Keypad Replacement: Schritt 3, Bild 3 von 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate Keypad Replacement, Sliding Front: Schritt 4, Bild 1 von 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Keypad Replacement: Schritt 5, Bild 1 von 2 LG Chocolate Keypad Replacement: Schritt 5, Bild 2 von 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Keypad Replacement: Schritt 6, Bild 1 von 2 LG Chocolate Keypad Replacement: Schritt 6, Bild 2 von 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Keypad Replacement: Schritt 7, Bild 1 von 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Keypad Replacement, LCD Board: Schritt 8, Bild 1 von 3 LG Chocolate Keypad Replacement, LCD Board: Schritt 8, Bild 2 von 3 LG Chocolate Keypad Replacement, LCD Board: Schritt 8, Bild 3 von 3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Keypad Replacement: Schritt 9, Bild 1 von 2 LG Chocolate Keypad Replacement: Schritt 9, Bild 2 von 2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Keypad Replacement: Schritt 10, Bild 1 von 1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Keypad Replacement: Schritt 11, Bild 1 von 1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Keypad Replacement: Schritt 12, Bild 1 von 2 LG Chocolate Keypad Replacement: Schritt 12, Bild 2 von 2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Keypad Replacement, LCD Screen: Schritt 13, Bild 1 von 1
    • The LCD screen is no longer connected to the LCD board.
  14. LG Chocolate Keypad Replacement, Keypad: Schritt 14, Bild 1 von 1
    • Push the keypad out from the front of the phone and remove it.
Abschluss
Maci Miri
39 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 19-46, Regan Winter 2013 Mitglied von Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 365
