Zum Hauptinhalt wechseln
LG Monitor 27MN60T Disassembly
Alan Nishioka
Alan Nishioka und eine weitere beteiligte Person
Zuletzt aktualisiert am March 12, 2021
Keine Schätzung
Mittel
In Bearbeitung
Anleitung eines Community-Mitglieds
The back of this monitor is held on with plastic clips. Before disassembly it is difficult to know where the clips are and what parts come off.
  1. LG Monitor 27MN60T Disassembly, LG Monitor 27MN60T Disassembly: Schritt 1, Bild 1 von 3 LG Monitor 27MN60T Disassembly, LG Monitor 27MN60T Disassembly: Schritt 1, Bild 2 von 3 LG Monitor 27MN60T Disassembly, LG Monitor 27MN60T Disassembly: Schritt 1, Bild 3 von 3
    • Back panel is held on with 30 plastic clips. The clip locations are circled in red.
    • 10 across the bottom. The clip sticks out from the black frame into the white back.
    • 8 across the top. The clip faces towards the center of the monitor. The clip sticks out from the white back into the black frame,
    • 6 along left and right side. The clip faces towards the center of the monitor. The clip sticks out from the white back into the black frame.
    • There is a single screw near the HDMI connector
    • Use a thin metal tool (jimmy) to slide between the white back and black frame to release the clips.
  2. LG Monitor 27MN60T Disassembly: Schritt 2, Bild 1 von 2 LG Monitor 27MN60T Disassembly: Schritt 2, Bild 2 von 2
    • Two more pictures showing disassembled monitor
Abschluss
Alan Nishioka
3.507 Reputation
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 4,851
