Zum Hauptinhalt wechseln
LG UD501KOJ5 Dehumidifier Sensor Replacement
Gabrielle Campbell
Gabrielle Campbell und 2 weitere Mitwirkende
Zuletzt aktualisiert am January 17, 2025
45 Minuten
Mittel
Benötigt Bessere Bilder
Bessere Einleitung
This guide will demonstrate how to safely replace a humidity sensor on your LG UD501KOJ5 dehumidifier.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: Schritt 1, Bild 1 von 2 LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: Schritt 1, Bild 2 von 2
    • Unplug the dehumidifier then put on work gloves to protect your hands.
    • Remove the water collection bucket and set it aside.
    • Remove the air filter from the bottom of the front grille.
  2. LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 2, Bild 1 von 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 2, Bild 2 von 2
    • Using your Phillips #0 screwdriver, remove the two screws which are attached at the bottom of the front grille.
    • Lift the front grille up and off the front of the frame, carefully set it in front of the dehumidifier.
    • The control board wire harness is still attached to the back of the front grille.
  3. LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 3, Bild 1 von 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 3, Bild 2 von 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 3, Bild 3 von 3
    • Remove the screws that secure the back panel to the dehumidifier.
    • Carefully remove the back panel from the dehumidifier.
    • Remove the screws at the side.
  4. LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 4, Bild 1 von 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 4, Bild 2 von 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 4, Bild 3 von 3
    • Remove the screws located at both sides of the back panel.
    • Remove the screws on the top left and top right which are connected to the control box.
    • Carefully remove the outer case.
  5. LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 5, Bild 1 von 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 5, Bild 2 von 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the sensor wire harness from the electronic control board.
    • Disconnect the wire harness from the collection bucket float switch.
    • Pull the evaporator thermistor out of the copper sleeve on the side of the evaporator coil.
  6. LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 6, Bild 1 von 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: Schritt 6, Bild 2 von 2
    • Remove the humidity sensor from the evaporator fins.
    • Pull the sensor assembly out of the dehumidifier.
    • Remove any dust build-up with a dry cloth.
    • Push the new humidity sensor in place on the front of the evaporator fins.
Abschluss
Gabrielle Campbell
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G3, O'Regan Summer 2021 Mitglied von York University, Team S1-G3, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G3
1 Mitglied
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 2,386
